1987 Pontiac Firebird car turns but doesn't turn over
THEBLOCC52
  • 1987 PONTIAC FIREBIRD
Engine Mechanical problem
1987 Pontiac Firebird V8 Two Wheel Drive Automatic
my firebird formula turns but doesn't turn over
Monday, August 16th, 2010 AT 12:12 AM
Cranks but no start condition-do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, August 16th, 2010 AT 12:28 AM
