First use a multi-tester to test from the red wire to ground (engine) to make sure you have a 12 volt circuit to the starter. If not. The engine may not be grounded properly (check the ground strap), or the battery lead to the battery is loose or defective. If this is not the problem try shorting across the strarter relay/solonoid with a screw driver or jumper wire. If the starter turns. It's electrical (possibly the ignition), if not. Something is wrong with the starter or relay/solonoid.
SPONSORED LINKS
Monday, July 31st, 2006 AT 12:54 PM
