1995 Pontiac Bonneville Lights and Locks
BAUERLD
I have a 95 Pontiac Bonneville V-6, 3.8 Liter engine with 110K miles. My AC compressor just went out and I took the car to an ASE certified repair shop for a new compressor.
The job was completed but now my interior lights do not come on when the doors are open and my remote access/door lock keys do not work. The interior lights do come on when the dimmer switch on my headlights on/off button is activated.
The repair shop did remove the battery cables during the removal/installation process of the compressors. It this fact important? Did it effect my CCM, computer control module in any way?
Also, my interior door panel power door lock/open switches do work properly when activated. The repair shop has been poking and probing for the last three days but without any success.
Can you help? Please respond one way or the other.
Oct 27, 2007 at 10:40 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4881312484="bauerld"]I have a 95 Pontiac Bonneville V-6, 3.8 Liter engine with 110K miles. My AC compressor just went out and I took the car to an ASE certified repair shop for a new compressor.
Can you help? Please respond one way or the other.[/quote:4881312484]
I will give some ideas and some questions too
Does the light come on if you try different door
Does the lock switch work on the other door?
In the door jam (when open the door look where the hinges u will see a black tube like coming frame the car to the door )
Very common the wires that run throw it brake up a lot
And also check the fuses and relay
See if you have fuses in or under the clove box
Good luck
Oct 27, 2007 at 3:16 PM
Suggested Repair
Compare both doors for courtesy lights and lock switches. Inspect the door-jamb wiring boots for broken wires, and check fuses and relays, including those in or under the glove box.
Conversation Summary
After an AC compressor replacement that included battery disconnection, a 1995 Pontiac Bonneville no longer turns on interior lights when the doors open and the remote locks do not work. Manual dimmer lighting and door-panel lock switches still work. The expert suggested comparing both doors, inspecting the door-jamb wiring boots for broken wires, and checking fuses and relays, including those in or under the glove box.
