1997 Pontiac Bonneville Courtesy Lights Stay On
GMC
DJR995
I have a 97 Bonneville SE and the courtesy interior lights won't turn off until the BCM waits 10 minutes. I have replaced the BCM, headlight switch and the drivers door latch/switch combo. I have checked the other door latches too. Nothing has helped so far.
I have pulled the fuse because I can't find the problem. Any suggestions would be appreciated.
Apr 11, 2006 at 11:57 PM
LOSONE
  • 1,616 POSTS
There is a separate relay in the relay center. It is an instrument light relay. There is also a remote accessory control modue that might cause the problem because it controls the relay and it has a built in timer.
You also have an adapative light monitor module that has a remote chance of causing the problem.
Let me know
Apr 12, 2006 at 5:00 AM
Suggested Repair
Check the instrument light relay in the relay center. Also inspect the remote accessory control module, which controls that relay and has a built-in timer. The adaptive light monitor module is a less likely cause.
Conversation Summary
A 1997 Pontiac Bonneville SE has courtesy lights that stay on until the BCM times out after about 10 minutes. The BCM, headlight switch, and driver door latch/switch were replaced, and the other door latches were checked, without success. The expert suggested checking the instrument light relay, the remote accessory control module that controls it and includes a timer, and, less likely, the adaptive light monitor module.
