Hard Cranking
MDV3441
  • PONTIAC BONNEVILLE
1997 Pontiac Bonneville 3800 V6
150000 miles
Automatic
2 Wheel Drive
Every time I try to start engine the starter hesitates (less than one revolution) like low/dead battery then engine turns over and starts. Much worse when up to temperature like dead battery. Checked battery and for grins installed new fully charged battery, no help, in fact it has almost 2X cranking amps as old but acted the same. Alternator charging 13-14 volts.
Thursday, May 31st, 2007 AT 8:37 AM
The overrunning clutch in the starter is gone, you probably need a new starter.
Friday, June 1st, 2007 AT 5:06 PM
