1988 pontice bonniville will not start gas is in the oil .i change oil it will run for little while, 8 cycle
Sep 5, 2007 at 2:21 PM
✓Experienced Mechanic
[quote:03cbe6a194="cpoe"]1988 pontice bonniville will not start gas is in the oil .i change oil it will run for little while, 8 cycle[/quote:03cbe6a194]
Could be the fuel pressure regulator and injector/s leaking and finding its way to the crankcase.
Sep 5, 2007 at 3:17 PM
COSTADELBOY
MEMBER
I don't Know your motor but this normally happens to engines with mechanical fuel pumps, the diaphram has a pin hole or rupture allowing the gas to pass thru and mix with oil. When it gets realy bad the pump stops working and the vehicle won't start
