2000 Pontiac Bonneville Engine Quits
MERGY
2000 Pontiac Bonneville SSEI, 78000 miles, 3,8 liter supercharged.
while driving the engine quits. Random event. Computer shows no fault codes, fuel pressure checked and fine. Battery voltage 14.4vdc.
Sep 5, 2007 at 9:57 AM
  • 75,988 POSTS
Check the connections on the cam and crank sensors located below
https://images.2carpros.com/forum/automotive_pictures/12900_bonneville_cam_and_crank_sensors_1.jpg
Sep 5, 2007 at 10:27 AM
Suggested Repair
Check the connections on the camshaft and crankshaft position sensors.
Conversation Summary
A 2000 Pontiac Bonneville SSEI with a 3.8L supercharged engine randomly quits while driving. There are no fault codes, fuel pressure is fine, and battery voltage is 14.4 V. The expert advised checking the connections on the cam and crank sensors.
