My car is a SE with the 3800 motor it has about 180,000 miles. The problem is it'll start fine and drive or idle for about 15-20 minutes. After that it just starts and dies, always starts fine and will stay running if you keep the RPM's above 2000 or so. If you let it sit for 4-5 hours, back to the same it'll start and run for awhile then die. This problem sounds kind of similar to the other 92 Bonneville problem. I have replaced the fuel filter and pump. Any help would be appriciated! This car is pretty old and I am hoping it is something easy.
Thanks!
SPONSORED LINKS
Monday, July 2nd, 2007 AT 5:49 PM
