1993 Pontiac Bonneville Engine Stalls
APETERMAN
Hi my name is Amanda. I have a 1993 Pontiac Bonneville 3.8L with 205,000 miles on it. The car stalls when I'm driving, but it doesn't do it all the time. I was wondering if you could tell me where to find the PCM Relay.
Sep 20, 2007 at 10:37 AM
SERVICE WRITER
  • 9,123 POSTS
Only the SSE shows a relay box, but no relay, fuse 17 is for that. I doubt the relationship for the stalling however to the fuse.
I would think about cleaning the egr, idle control valve and intake valves.
Nov 5, 2018 at 11:11 AM
APETERMAN
I wanted to thank the mechanic who promptly responded to my question. I have had no luck as of yet with this problem. The only thing I have not done as of yet is cleaned the idle control valve. Thanks again so much. I will let you know how it goes.
APETERMAN
I have finally figured out the problem. I changed the Ignition Module and repaired 4 loose wires. My car runs like a dream now. Thank you for everything, and I hope this helps someone else.
Suggested Repair
The intermittent stalling was resolved by replacing the ignition module and repairing four loose wires. The expert had doubted a PCM relay or fuse 17 cause and suggested cleaning the EGR, idle control valve, and intake valves.
Conversation Summary
A 1993 Pontiac Bonneville 3.8L stalled intermittently while driving, and the owner asked where to find the PCM relay. The expert said fuse 17 relates to that circuit but doubted it caused the stalling, recommending cleaning of the EGR, idle control valve, and intake valves. The owner later reported that replacing the ignition module and repairing four loose wires fixed the problem.
