Drive Train Axles Bearings problem
2000 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
My 2000 Bonneville has a vibration only when accelerating and only between 46 & 54 mph. I have had the tires rotated and balanced 3 times. I have replaced the brakes rotors calipers. I replaced a worn tie rod end. I had a front end inspection done. I replaced both front hub assemblies. Any idea what could cause this. It shakes the whole car when accelerating lightly and if you let off the gas it stops instantly.
Nov 11, 2009 at 12:10 PM
