1998 Pontiac Bonneville
WAVECATCHER555
Engine Mechanical problem
1998 Pontiac Bonneville 6 cyl Automatic
I have a 1998 Pontiac Bonneville and when there is not alot of gas in the tank, the car is hard to start and will just keep cranking before it finally starts. And it seems like my car is sucking up gas alot more than it should. Plus, I don't know how much gas is in the car ever because the fuel gauge fluctuates frequently! Is there some main cause to all of these problems?!
Sep 16, 2009 at 6:48 AM
JDL
  • 16,098 POSTS
Welcome to the forum. I'd use a gage and check fuel pressure. you might try cycling the key, on and off, two or three times before you crank it, it might help to build pressure in the system?
Sep 16, 2009 at 8:52 AM
