1997 Pontiac Bonneville SE
TIM4U
  • 1997 PONTIAC BONNEVILLE
Hi I have a 97 bonneville se and I had dropped my son off at school and I return to start the car and it wouldn't start. I had the battery fully charged. I had someone jump start the starter and it turned over but did not start the car. I took the module to be tested and found out that it was no good so I bought a brand new one and the car still won't start. I had the key tested and found it wasn't the key and it still won't start. What do you think could be my problem?
Tuesday, November 14th, 2006 AT 7:32 PM
DCOYNEJ
  • 6 POSTS
First question. Is it turning over at all. If not. Does it make a small click? Like its trying to start. Or dos it make any sound at all? Should be the 3.8 motor, if its making a small click noise. But not turning over. Id first check that the battery is good, then pull the starter and have it tested, (its a pain), the worst case scenario, pull ath the plugs and try to turn it ovver if the starter showed good. If it blows a bunch of water/ antifreeze out of the cylinder, there is a small gasket around where the egr goes into the upper intake, should have been a recall but wasnt, you will have to replace the upper intake and at worst also the egr valve.
Wednesday, November 29th, 2006 AT 2:50 AM
Related Engine Not Running Content
