If I was to take an educated guess right now, I would say the crank position sensor is your problem. But you really should check for spark and fuel, this will determine which direction to turn, cause at this point there are quite a few posibilities, but through my experience, I would suspect the crank position sensor.
SPONSORED LINKS
Tuesday, October 19th, 2010 AT 1:33 PM
