166,000 Miles
3.8L V6
I have a code scanner, and my check engine light came on. I Scanned for codes and came up with Code P1655. The book that came with the scanner says that is a PCM Fault (Quad2). I dont know what that means. One repair guy I asked said that the PCM was going bad, so I bought a used PCM with matching serial numbers. I put the new(Used) one in and the car wont start. What does that code mean? Do I need to get the new(used) PCM reprogrammed or something?
SPONSORED LINKS
Monday, August 6th, 2007 AT 7:54 PM
