1992 Pontiac Bonneville fuel?
DEX_HUSTLIN
  • 1992 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 136,000 MILES
What would make your car not start back up, it runs fine for about 20 min the cuts off and wont start again for hours
Monday, March 1st, 2010 AT 7:13 PM
Do below to determine whether it's a fuel or spark issue.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, March 1st, 2010 AT 8:14 PM
Related Engine Not Running Content
