1992 Pontiac Bonneville Will not start ran for awhile 25mi
MOPARNUTT6709
  • 1992 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 102,000 MILES
Long story but detailed to assist proper diagnosis. Noisey harmonic balancer was replaced at local shop with correct new balancer, key was messed up, shop said he had to remove timing cover to replace messed up key. Both sensors replaced, new timing chain, since we were in the same area and car has 102,000, all was replaced, vehicle ran for about 25 miles and quit. Went back to shop, said not his problem. Had other shop look at vechicle, went to start vehicle and gm code 58 came up, tested key key was within spec's, tested wires at base of sterring column, same ohm reading within.03 and said that little bit of difference should not matter. Shop is stumpped, he said he can read rpm, fuel pressure, spark, injectors reading okay, but not releasing fuel into combustion chambers, he said the vehicle thinks it is been stolen, he has tried to trick the system using resistors to change the.03 ohm difference. Is there something we are not looking at? Missing something? Please help!
Thursday, October 22nd, 2009 AT 1:32 PM
If its getting spark-Tell him to check the fuel pressure and injection pulses
Thursday, October 22nd, 2009 AT 2:50 PM
MOPARNUTT6709
Getting good fuel pressure, injectors are pulsing, I did take afew spark plugs out and they are clean not fouled, and cannot smell any fuel in cylinders.
Thursday, October 22nd, 2009 AT 9:11 PM
Cannot smell any fuel in cylinders. You said fuel pressure is good and injector/s are pulsing and got spark it should be able start up-If not check the valve and ignition timing
Friday, October 23rd, 2009 AT 12:20 AM
