1991 Pontiac Bonneville Engine will not start
GARCIAROB
  • 1991 PONTIAC BONNEVILLE
Engine Mechanical problem
1991 Pontiac Bonneville Two Wheel Drive Automatic 153252 miles
All of the electrical items work, the head lights work, the dash panel lights all work, the power windows all work, mirrors, locks, heater, turn signals, flashers, everything works while the key is in the on position but the engine will not crank over, the battery is at a full charge of 12v. What can I do. Please help. Thank You.
Sunday, February 8th, 2009 AT 11:48 AM
JDL
  • 16,098 POSTS
Do you have a theft system? Have you tried cranking it in neutral?
Do you have ignition feed, small purple wire, goes hot with the key in the crank position. Any testing make sure the tranny is in park or neutral, set the e-brake.
Sunday, February 8th, 2009 AT 2:28 PM
