Code po303, cylinder three misfire
2008 NISSAN ALTIMA
200,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
RONRON59
I have a cylinder three misfire at a low idle. I have replaced plugs, coil and the plug connector as well as the reman injector. car still has the same code. any suggestions would be appreciated. thanks
Mar 13, 2022 at 3:18 AM
  • 110,244 POSTS
Since it stays on cylinder three and you notice it at idle, chances are it could be low compression on that cylinder. You did confirm there is spark to cylinder three and an injector pulse, correct? Also, just to confirm, you only notice it at an idle, correct? What is likely happening is as the RPMs increase, the misfire is still present but not as noticeable.
Based on the miles and what has already been done, that is what I would recommend checking next. You have already tried all the electrical components. If it was a random misfire and not specific, then I would think it could be something different.
Here is a link that explains how to test engine compression. You will need a compression gauge, but most parts stores will lend one to you free of charge.
Mar 13, 2022 at 10:44 AM
