1999 Plymouth Grand Voyager Rear Plugs Fix
BETTYCHAT
1999 Plymouth Grand Voyager SE V6 3.3 liter engine 87,000
How do I replace the three "back" spark plugs on this vehicle?
Apr 13, 2006 at 2:51 AM
LOSONE
  • 1,616 POSTS
They can be reached from under on rack. You can also disconnect the front engine mount and roll the engine forward but be careful. It is a job for a professional. Good Luck
Apr 13, 2006 at 11:10 AM
Suggested Repair
Access the rear spark plugs from underneath on a lift. Alternatively, a professional can disconnect the front engine mount and carefully roll the engine forward to reach them.
Conversation Summary
The owner of a 1999 Plymouth Grand Voyager SE with a 3.3L V6 asked how to replace the three rear spark plugs. The expert said they can be reached from underneath on a rack, or by disconnecting the front engine mount and carefully rolling the engine forward, and recommended a professional do the job.
