1996 Plymouth Grand Voyager Condenser Leak Fix
CHRISACRES
  • 5 POSTS
plymouth gran voyager 1996 3.8
Hopefully the last question (for a while at least...i hope)
the air conditioning condenser has a leak. can it be repaired or do i have to buy a new one?
If i do, is it just the condenser that i need to replace, or are there any other parts that are integral to the repair?
The leak is at the bottom left of the condenser (below allt he connections. if that makes any difference)
thanks guys
Chris
England
Jan 27, 2007 at 6:30 PM
CARUNDELL
  • 602 POSTS
[quote:13b0166ebe="chrisacres"]plymouth gran voyager 1996 3.8
thanks guys
Chris
England[/quote:13b0166ebe]
Hey Chris,
Has to be replaced, unless you know someone thats very very good with a tig welder and can then pressure test it for you? But then by that time your labor costs will probably have equaled/exceeded the cost of a new one! Let us know!
Chris
Jan 27, 2007 at 9:53 PM
Suggested Repair
Replace the leaking AC condenser. A TIG weld and pressure test is only practical with a highly skilled welder, and the labor usually costs as much as a new condenser.
Conversation Summary
The owner of a 1996 Plymouth Grand Voyager 3.8 reports an air conditioning condenser leak at the bottom left, below the connections, and asks whether it can be repaired or must be replaced and if other parts are required. The expert says the condenser should be replaced unless a very skilled TIG welder can repair and pressure-test it, noting that labor would likely equal or exceed the cost of a new unit.
