1993 Plymouth Voyager Rough Idle
JONNYFIVE02
I have a 1993 Plymouth Grand Voyager..3.3 liter..189 thousand miles. The engine runs rough like it has a skip. It seems to be worse at idle but there is also just a slight miss at higher RPM's. So far i've replaced plugs PCV valve and air filter. All of the vaccum lines look good plug wires are fine..How would I know whether to replace them or the coil. I was sure that the skip would straighten out after i replaced the spark plugs but I can't seem to get it to run right.
Jan 15, 2007 at 7:37 AM
SERVICE WRITER
  • 9,123 POSTS
Try this, mist some water on the ignition wires from one end to the other. See if the idle changes or roughness is observed. Also look for arcing.
What did you r plugs look like? all the same some dark some white, etc.?
Jan 15, 2007 at 10:27 AM
Suggested Repair
Mist water along the ignition wires and watch for an idle change or arcing before replacing the wires or coil. Also compare the old spark plugs for even color versus some dark and some white.
Conversation Summary
The owner of a 1993 Plymouth Grand Voyager 3.3L reports a rough idle and a slight miss at higher RPM after replacing the plugs, PCV valve, and air filter. Vacuum lines and plug wires appear fine. The expert advises misting water on the ignition wires to see if the idle changes and to look for arcing, and asks whether the old plugs were evenly colored or some were dark and some white.
