HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Plymouth
Voyager
Engine
Symptoms
Misfire
SPONSORED LINKS
Plymouth Voyager 1996
FISHER4JESUS
MEMBER
1996 PLYMOUTH VOYAGER
MISS FIRE IN CYLENDER 6
Tuesday, March 20th, 2007 AT 1:56 PM
GREG MORRIS
MEMBER
Not much info to go on. How do you know it's cylinder 6?
Check condition of fuel injector, spark plug, and wire.
Check compression.
SPONSORED LINKS
Saturday, March 24th, 2007 AT 3:38 PM
MERLIN2021
MECHANIC
I like the answer!
Monday, April 2nd, 2007 AT 3:47 PM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
1997 Plymouth Voyager Car Barely Runs
Car Runs Bad. Will Not Go Unless The Throttle Is Pushed All The Way To Floor? Codes Po443, Po132, P1899, Po172. I've Been A Mechanic For...
Asked by
patchho
1 ANSWER
1997
PLYMOUTH VOYAGER
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
Engine Miss
What Will Make A 3.3 Miss And Backfire Only When Warm
Asked by
mathiasim
1991
PLYMOUTH VOYAGER
1997 Plymouth Voyager Misfire At Normal Temperature
I Have A Chrysler Voyager Which Misfires When Gets To Normal Temperature. Did A Scan. Code Said Coil Primary Circuit, Bought New Coil...
Asked by
taylorbuilt
1997
PLYMOUTH VOYAGER
1999 Plymouth Voyager Skipping
I Had Van Checked Out At Auto Zone The Check Engine Light Has Been On Forever But The Reason I Had It Checked Was Because Of The Skip That...
Asked by
Robbie Anders
1 ANSWER
1999
PLYMOUTH VOYAGER
1998 Plymouth Voyager Check Engine / Misfire
Ok, Failed Emissions Due To Obd Failure With Random Misfire Errors. Did Tuneup. Plugs Wires Cap Rotor Air Filter. Reset Ecm At The...
Asked by
jefflaitinen
1 ANSWER
1998
PLYMOUTH VOYAGER
VIEW MORE
SPONSORED LINKS
Online car repair manuals
