1994 Plymouth Voyager Rough Idle Backfire
VIPER6250
I have a 1994 voyager 3.3 litre it back fires when in drive under load through the throtle body and runs rough in park it does not back fire in park and it started to idle high at 2000 rpm in park and in drive now and throttle body sounds very loud now when sucking air in what could the problem be
Jan 5, 2007 at 5:59 PM
SERVICE WRITER
  • 9,123 POSTS
Check for a vacuum leak for starters. Excessive air will give a high idle. Just follow your ears. When you get to where a sucking air sound is, spray a little carb cleaner in that area and listen for an idle change.
Jan 5, 2007 at 11:02 PM
Suggested Repair
Check for a vacuum leak. Follow the loud air-sucking sound, spray a little carburetor cleaner in that area, and listen for an idle change. Excess unmetered air can cause a high idle.
Conversation Summary
The owner of a 1994 Plymouth Voyager 3.3L reports backfiring through the throttle body in drive under load, a rough idle in park, a high idle around 2000 rpm, and a loud air-sucking sound at the throttle body. The expert recommends checking for a vacuum leak by locating the sucking sound and spraying carburetor cleaner while listening for an idle change.
