Thursday, June 11th, 2009 AT 7:46 PM
I have put a new fuel pump, fuel filter, idol pos sensor, map sensor, air filter, checked the injectors, new plugs and wires, had the timeing checked, cleaned out the throttle boddy, checked all of the vacume hoses checked the compression and I am at a loss. It will start sometimes, when it does you can smell gas like it is fluding and if you let up on the gas or put it into any gear besides park and neutral it will die out. I am out of money and luck to put into it Please help any way that you can
