1999 Plymouth Voyager Stalling
DALEH5
  • 1999 PLYMOUTH VOYAGER
Engine Performance problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
My 1999 Plymouth Voyager stalls when turning after the engine is warm. Also when it is warm, I will shut it off and when I go to restart it it spits and sputters and pops for a bit un til it starts to go again. I have been t5old that the only codes in the computer are P0171 and P1294
Friday, April 23rd, 2010 AT 9:40 AM
2CARPRO JACK
  • 11,533 POSTS
The P0171 is fuel system rich/lean, the P1294 is target idle not reached. Try removing the intake tube where it attaches to ththrottle body.Clean out around the butterfly in thethrottle body, then there is an idle speed motor attached to the throttle body, remove it and clean it with carb cleaner and a rag (same as throttle bore).this should bring the idle back up to where it is supposed to be. The valve should look similar to this
https://www.2carpros.com/forum/automotive_pictures/1639_AC163_1.jpg
Tuesday, April 27th, 2010 AT 10:32 PM
