Do you have a remote car starter installed?
If your not sure look for an antenna usually above the rear view mirror
these aftermarket starter can cause all kinds of problems and have seen them do this exact thing many times before
if it does have one unplug it these are always found under the dash on the left(drivers side) will be a black box that might just be stuffed in around the colum or if it was install properly will be secured with tie straps
SPONSORED LINKS
Thursday, July 17th, 2008 AT 12:15 AM
