1999 Plymouth Voyager collimg fans
RANDCMERKLIN
  • 1999 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 111,305 MILES
Coolimg fans won't shut off when car is shut off replaced thermostat and coolant tempratere sensor but did not fix proublem
Thursday, November 6th, 2008 AT 2:42 PM
DAVE H
  • 13,383 POSTS
This is from a technical service bulletin from 1997 models. But it sounds like it could be the same fault.
SYMPTOM/CONDITION
After an ignition start cycle the Compass Mini-Trip Computer (CMTC) and/or instrument cluster display may intermittently malfunction as follows:
The display shows incorrect temperatures.
The display will go into the "CAL" mode.
The display shows an incorrect heading.
The display is blank.
All instrument cluster gauges and all Vacuum Fluorescent (VF) displays are out/blank.
DIAGNOSIS
If the vehicle demonstrates or the vehicle operator describes any of the five symptoms above, perform the following Repair Procedure.
PARTS INFORMATION
PARTS INFORMATION
Part NumberDescriptionQty.
04897438AARelay, Current blocking, Electrical Back Light1
REPAIR PROCEDURE
This bulletin involves installing a revised Electric Back Light (EBL) relay.
Disengage the two slotted fasteners on the instrument panel silencer assembly/junction block cover and remove silencer/cover.
Remove the EBL relay (located in the lower left corner of the junction block and immediately above the fuse bank) and discard it.
Install the revised EBL relay P/N 04897438AA.
Install the instrument panel silencer assembly/junction block cover.
WARRANTY INFORMATION
Tuesday, November 11th, 2008 AT 7:31 PM
