1999 Plymouth Voyager Changing spark plugs
DAVID KEGLEY
Engine Mechanical problem
1999 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
How do you get to the three plugs on the back?
There is no room to got to them.
Nov 14, 2009 at 4:43 AM
KNOWYOURAUTO
  • 113 POSTS
There are several methods that can help but nothing is going to make it easy. The removal process is almost totally by feel becaus of limited clearance.
Some access can be gained by removing a few components on the passenger side of the engine closest to the firewall. (Brackets) Older models had plenty of room from underneath if you follow the exhaust up to the engine, but this year is quite different. Still, support the vehicle sturdily and take a look.
Good Luck,
Nov 16, 2009 at 2:50 PM
