On V-6 models only, remove the windshield wiper/motor module assembly from the vehicle for access to the spark plugs on the firewall side.
Carefully twist the spark plug wire boot to loosen it, then pull upward and remove the boot from the plug. Be sure to pull on the boot and not on the wire, otherwise the connector located inside the boot may become separated.
Using compressed air, blow any water or debris from the spark plug well to assure that no harmful contaminants are allowed to enter the combustion chamber when the spark plug is removed. If compressed air is not available, use a rag or a brush to clean the area.
SPONSORED LINKS
Saturday, May 2nd, 2009 AT 12:47 AM
