1998 Plymouth Voyager
RVERA1221
  • 1998 PLYMOUTH VOYAGER
Electrical problem
1998 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
How to reset blinking wiper and washer lights?
Wednesday, September 15th, 2010 AT 9:43 PM
CARADIODOC
  • 33,916 POSTS
Hi rvera1221. Welcome to the forum. Try this first. It's a copy / paste version from the Chrysler web site but it is different than what I remember. These calibration tests must be done after the battery is disconnected or run dead. The cool down test can be very frustrating. I've had to do it as much as 20 times before it passed. It might help to do that one right after driving at highway speed to get the engine good and hot. Also, it will not pass if the air conditioning isn't working properly.
Caradiodoc
ACTUATOR CALIBRATION/DIAGNOSTICS AND COOLDOWN TEST
GENERAL INFORMATION
If the HVAC control module is replaced, the Calibration Diagnostic and Cooldown tests will need to be performed. Once this group of tests have successfully passed, they can be performed individually. The engine must be running during the test to provide hot coolant for the heater, A/C compressor operation and to assure that the actuators are calibrated correctly. The HVAC control module is capable of troubleshooting the system in approximately 120 seconds. If a condition is detected, an error code is displayed. The error code cannot be erased until the condition is repaired and the diagnostic test is preformed. Check wire before replacing components, Refer to Wiring diagrams
CAUTION: Do not remove the actuators from the Heater-A/C unit assembly with power applied. Removal should only be done with the Ignition OFF. The actuators have no mechanical stops to limit the travel. If the actuator rotates and is not connected to the unit assembly, it will become out of calibration.
CALIBRATION/DIAGNOSTICS TEST ENTRY
TO INITIATE TESTS:
à † Set Blower motor ON HIGH
à † Set Mode position to Panel
à † Set Temperature to Cold (Both slide pots if equipped)
à † Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light)
RESULTS:
à † All LED's will turn on for 5 Seconds
à † Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.
à † Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
à † After all tests have passed, Calibration Diagnostics and Cooldown can be run separately.
COOLDOWN TEST ENTRY
TO INITIATE TESTS:
à † Depress WASH and A/C simultaneously for 5 Seconds
NOTE: If the evaporator is already cold, operate system with A/C OFF and the blower motor ON high for three minutes prior to starting test.
RESULTS:
à † All LED's will turn on for 5 Seconds (Until all LED's light)
à † Cooldown Test is running when A/C and RECIRC. Are alternately flashing. If A/C and RECIRC. Are flashing simultaneously, Cooldown has failed. Make sure that the Blower motor is ON high, and temperature is ON full Cold, abort test and repeat Calibration Diagnostic and Cooldown test again.
à † Calibration Test is running when REAR WIPER and INTERMITTENT LED's are alternately flashing.
à † After all tests have passed, Cooldown test can be run separately.
CALIBRATION DIAGNOSTICS AND COOLDOWN ABORT
Test can be aborted by doing one of the following:
à † Depressing Rear Window Defogger, RECIRC and Rear Wiper buttons.
à † Cycling Ignition OFF and then ON.
à † Control will automatically abort after 15 minutes from the time Calibration Diagnostics and Cooldown was entered.
The HVAC control module will return to normal operation or may indicate unsuccessful Calibration Diagnostics or Cooldown test by LED's flashing simultaneously.
NOTE: Do not run actuators unless they are properly mounted on the HVAC control module.
Tuesday, October 12th, 2010 AT 10:37 PM
