1995 Plymouth Voyager Rear windshield fluid won't work
SRICHARDSON1212
All of the sudden my washer fluid won't spurt out on my rear windshield. I have added fluid to the tank, so I know it's full. The rear windshield wipers work with no problem but no fluid will come out. What can be the cause?
Dec 10, 2009 at 10:50 PM
CARADIODOC
  • 34,413 POSTS
Do you hear the motor run when you press the button? This system is one of the few things the engineers haven't stuck a computer on yet so reliability is pretty high. If the rear wiper turns on when you press the washer button, that tells you the switch assembly is working. Suspect a locked up and / or corroded pump motor if you can't hear it run. If you do hear it running, look for blue juice running out from the wrong place indicating a cracked or disconnected hose.
caradiodoc
Dec 12, 2009 at 12:54 AM
