1997 Plymouth Voyager Ignition/ Battery
131,000 MILES • 6 CYL • FWD • AUTOMATIC
JANINE1
The battery will turn over but won't 'crank'. I ran out of gas...initially...car never would start afte that....have replaced fuel punp...fuel filter...spark plugs....The battery is well charged an turns over but won't ignite/ 'catch'....what else could the problem be?
Feb 2, 2008 at 2:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:817901fe07="janine1"]Other Category problem
1997 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 131000 miles
The battery will turn over but won't 'crank'. I ran out of gas...initially...car never would start afte that....have replaced fuel punp...fuel filter...spark plugs....The battery is well charged an turns over but won't ignite/ 'catch'....what else could the problem be?[/quote:817901fe07]
So engine cranks but will not start
Check fuses and relay
check ASD relay
and also you can cycle the key ON OFF three times
ending with key ON read if you have any codes in the odometer area if no codes will say done
or will read P####
let me know if you have any codes
that my help to tell what is going on
check if you have a spark and if you have fuel pressure or if the pump comes on
let me
Feb 2, 2008 at 5:36 AM
