Can't expect an answer if you won't provide some information. Which engine do you have? Which transmission, 3 or 4 speed? The four speed will have a big "O" around the letter "D" in the gear indicator in the instrument cluster. What is the symptom or problem you're trying to solve? Which switch or sensor are you trying to find? There's a bunch of them.
SPONSORED LINKS
Sunday, February 21st, 2010 AT 9:05 AM
