1997 Plymouth Voyager
EVANSJU1
  • 1997 PLYMOUTH VOYAGER
i have a vibration in the right front quadrin of the van near the cv joint. Im not sure if its the cv joint or the ball bearing. Do you know what it might be? I need to know to get the right part.
Friday, December 25th, 2009 AT 11:49 PM
CARADIODOC
  • 33,916 POSTS
If you feel it in the steering wheel, only under acceleration, suspect the inner cv joint housing, usually the right side. Rather than blindly throwing parts at it which is a very ineffective and costly way to find a problem, I figured out how to check the joint but it's pretty involved. If you just replace the half-shaft, be aware a lot of remanufactured shafts have the same problem because the cause is easy to overlook.
Caradiodoc
Sunday, December 27th, 2009 AT 9:29 PM
EVANSJU1
So should I replace the cv boot?
Sunday, December 27th, 2009 AT 9:49 PM
CARADIODOC
  • 33,916 POSTS
The boots have nothing to do with shaking. To check if the joint is the problem, you must jack up the vehicle, then remove the cotter pin, lock washer, anti-rattle wave washer, and axle nut. Never allow the vehicle's weight to rest on a front wheel with the axle nut removed or even just loose. It will instantly cause the wheel bearing to become noisy. The bearing is held together by the outer cv joint and nut.
Use your thumb to push the axle shaft in toward the center of the vehicle. It should push hard, about an inch, and pop back out quite forcefully. If it does not pop back out, the spring in the inner joint is broken. New ones from the dealer are about four bucks.
To inspect the inner housing, the shaft must be removed from the vehicle and be disassembled. There are six polished surfaces that the three rollers run on. Run your finger over all six of them. If you can feel the slightest irregularity, you REALLY have junk. If you don't feel anything, clean out the grease and wash and dry the rolling surfaces, then shine a light in there and look at the reflections, similar to looking at the reflection of the ground in the body of a car at a car show. Any waviness will cause the rollers to bind when you're accelerating. The shaft will not be able to change length as it rotates. That will cause it to push on the steering knuckle and linkage. That's what causes the steering wheel to wobble back and forth. Remember, this only applies to a shaking steering wheel when accelerating and will be more noticeable if you're turning at the same time.
Caradiodoc
Monday, December 28th, 2009 AT 2:23 AM
