Symptoms of a Bad Automotive Drivetrain CV Axle
symptoms of a bad automotive cv axle
Introduction
CV axles different than a normal straight axle, and with that come different symptoms when the CV axle is having an issue. These axles allow the movement of suspension and steering parts while delivering engine power to the wheels. CV axle's are designed with a circular rubber boot that is responsible for holding the lubricating grease inside the CV joint.
What Goes Wrong?
Most of the time when a CV axles goes bad it will do so in one of two ways, the CV joint will wear out and make noise/vibration, or the CV axle shaft will break and stop the vehicle from moving. Though there is not much that can be done to prevent the shaft breakage inspection can help prevent a failure. The CV joint is protected by a grease retaining rubber boot, this boot should be inspected to ensure there is no leakage. Look for grease splattered around the wheel well or under the vehicle. If you see any signs of grease as in the image below the CV axle should be replaced.
automotive drivetrain cv axle boot leak
Common Symptoms of a Bad CV Axle
  1. By far the most popular sign the CV axle is going out, is in a sharp turn at slow speeds, the instant you accelerate in the turn you will hear a popping or clicking noise. This means the CV axle is worn out, if you are turning left and you hear the noise, the left hand CV axle is worn out, and visa versa.
  2. Under acceleration a worn out CV axle will cause vibrations at higher speeds of 35 to 55 MPH under power only, when you let off of the accelerator the vibration stops. This is because the balls in the CV joint have worn into the outer cup hindering the smooth radial movement of the joint.
  3. If a CV axle breaks completely, the car will be rendered non operational. This is because the opposing axle will not be able to move the car due to the differential spider gears which will spin internally, not delivering the engine's power to the remaining axle.
Credits
This guide knowledge base was created by the 2CarPros Team. If you have a car repair question, you can ask the 2CarPros community for help. Please visit our 2CarPros YouTube Channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
