Monday, March 31st, 2008 AT 6:04 PM
I have a 96 Voyager check engine light came on and the mechanic said it was an o2 sensor, replced 3 days later the car turned off and the light came back on. What can be the problem I have changed the o2 sensor, cam shaft sensor, crankshaft sensor as well because all thiese were codes thatcame up on the diagnostic. The car also takes a while for its temp. To reach it level so I will replace the thermostat and do a radiator flush. What can be the couse of my check engine light.
