You can retrieve the trouble code(s) that are stored by using the check engine light. To do this, turn the ignition ON and make sure the light comes on for 3 seconds then goes off. If OK, attempt to start teh engine. Turn ignition off. Without starting engine, turn ignition ON, OFF, ON, OFF and then ON within 5 seconds. The light will flash 2-digit codes. For example, a code 24 will be 2 flashes, short pause, then 4 flashes. Let me know what code(s) you get and I will follow up.
SPONSORED LINKS
Friday, March 19th, 2010 AT 8:58 PM
