1996 Plymouth Voyager check engine light
RTJAYS
  • 1996 PLYMOUTH VOYAGER
  • 4 CYL
  • FWD
  • 129,000 MILES
Check engine light has been ramdomly coming on and going off. It is now blinking. The van is running good. What should I check
Tuesday, April 15th, 2008 AT 8:10 PM
MASTERTECHTIM
  • 4,750 POSTS
If the check engine l;ight is blinking then the truck is not running good. A blinking check engine light means there is a engine skip thaqt is so bad it will cause catalytic converter to fail if you keep driving it. Check plugs and wires.
Tuesday, April 15th, 2008 AT 8:14 PM
