I have changed the fluid and filter. Before changing the transmission. Is there anything I can do to make the transmission start shifting. It stays in one gear. It will go up to 60 plus miles per hour. It just want shift into a another gear. This makes the RPM run at around 4000 plus rpms.
SPONSORED LINKS
Thursday, August 13th, 2009 AT 7:10 AM
