1989 Plymouth Voyager will not shift
BRUCE BLANCHARD
  • 1989 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 142,000 MILES
The transmission is "stuck" in 1st gear. I have changed fluid and filter, linkage is ok. What do I do next?
Monday, June 15th, 2009 AT 1:35 PM
You need to get the transmission pressure tested to find out more
Monday, June 15th, 2009 AT 3:24 PM
MIKEYDAP
  • 6 POSTS
Sounds as if you may be in "limp home mode" which is actually 2nd gear. This occurs when one or both transmission speed sensors go bad. $17 each and get a deep dish socket to replace them.
Of course, get the tranny pressure tested as rasmataz noted.
Saturday, June 27th, 2009 AT 9:48 PM
