1996 Plymouth Voyager shifting
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SHOWGUN101
i have replaced transmission 3 time the same happens every time it wont shift into high gears replace all the switch and sensor it still does the same thing
Feb 18, 2008 at 10:48 AM
BMRFIXIT
  • 19,053 POSTS
OK you got my attention
you have a black box on the side of the tranny with about 6 or so wires
it called solenoid packs
that is the most common to fail and if its OK and you said that you replace the TCM then check the wiring between TCM and solenoid pack
(its in front on the tranny by the cooler lines )
good luck let me know
Feb 18, 2008 at 11:40 AM
