1996 Plymouth Voyager 96 Voyager
DAWNBEAVER
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 167,000 MILES
The dealer said that the diagnostic test is reading that its a crank sensor but a new one was already put on. They checked the fly wheel and thats not the problem either its cranking like it wants to start but it just wont crank over. Thier saying that its not getting any spark as far as the timing they said I have a chain and not a belt and that if it was the chain it would be making a lot of noise and its not. Anyone have anything else they know that we may be able to try. They have also already put in a whole new computer and the same code is coming up that its not reading the crank sensor
Saturday, September 19th, 2009 AT 8:57 AM
BMRFIXIT
  • 19,053 POSTS
Depending on the code #s
but if a crank sensor was replace and new PCM too
you left with the wiring harness and that need to be checked
very common for a wire to pull out the pins harness
Thursday, September 24th, 2009 AT 6:40 AM
