1995 Plymouth Voyager
SJBUECHE
I have a 1995 Plymouth Voyager. It sometimes hesitates or sputters and then dies. It will start right back up. Usually when coming to a stop. The fuel line was kinked and pinched, had that repaired, new fuel filter, new air filter, new oil and oil filter. Can you tell me what other possibilities it coul dbe without keeping on spending money trying to figure out what is oging on?
Mar 1, 2010 at 9:03 AM
LEGITIMATE007
  • 5,121 POSTS
i suspect the idle air control valve is dirty or faulty and need cleaning or replacement
Mar 1, 2010 at 9:09 AM
LEGITIMATE007
  • 5,121 POSTS
you may want to clean the throttle body and throttle plate too, as this will help clear the stumbling
Mar 1, 2010 at 9:10 AM
SJBUECHE
Thank you!
Mar 1, 2010 at 9:27 AM
LEGITIMATE007
  • 5,121 POSTS
no problem, keep me posted as to what happens
Mar 1, 2010 at 9:43 AM
SJBUECHE
a friend of ours thought it may be the O2 sensor????
Mar 1, 2010 at 11:19 AM
LEGITIMATE007
  • 5,121 POSTS
thats quite possible, but is there a check engine light on? because the function of a o2 sensor is once the exhaust warms it it in turn sends a signal to the ecm to go into "closed loop" once that happens then the vehicles sensors take over . until then it runs on a base set of parameters.
Mar 1, 2010 at 11:07 PM
