1992 Plymouth Voyager Turn Signals
1992 PLYMOUTH VOYAGER
208,000 MILES • 6 CYL • FWD • AUTOMATIC
HOLZI
Recently, my turn signals and hazard lights stopped working. At first, it was intermittent, but they finally completely stopped. Fuses are good, I can't find the flasher to try, and the turn signal switch is between $69-$85. I'd rather start at the low end! Thanks!
Dec 15, 2009 at 7:01 AM
JDL
  • 16,098 POSTS
Welcome to the forum, any fuses you checked, did you use a testlite on the fuse circuit? turn fuse is number 7--20 amp, according to my info. The turn/hazzard flasher shows to be behind left end of instrument panel in relay block.
Dec 15, 2009 at 7:31 AM
