Turn signal bulb replacement on 99 Plymouth Voyager
95,000 MILES
PLDOKKEN
I am trying to replace the front turn signal bulb on my 99 Plymouth voyager. I can reach the bulb socket and turn it about 1/4 of a turn counter clockwise but I cannot pull it out no matter how hard I try. Any ideas?
Sep 4, 2013 at 9:52 AM
TY ANDERSON
  • 719 POSTS
If you can't get to it very well you may need to remove the head light to make it easier and so you don't crack any of the 14yr old plastic. It is either the o-ring seal is causing the socket to jam or the socket it not fully turned to the released position. Let me know if you have any more questions, TY
Sep 4, 2013 at 11:04 AM
PLDOKKEN
What bolts/screws do I need to take out to get the headlight lens out?
Sep 4, 2013 at 1:28 PM
TY ANDERSON
  • 719 POSTS
If I remember right there is one bolt on top of the headlight assembly and three on the back side (10MM nuts/bolts). With all four fasteners out the headlight should slide out towards the front of the vehicle which then gives you access to the turn signal bulb and wiring. Hope this helps. Talk to you soon, Ty
Sep 4, 2013 at 2:36 PM
