1992 Plymouth Voyager Parking brake light and ABS light on
PAPADEE
  • 1992 PLYMOUTH VOYAGER
  • 6 CYL
  • AWD
  • 150,000 MILES
My ABS light is on and the parking light. The parking brake seems to work fine, it does not appear to be locked. I found a crack in the ring on the passenger side ABS axle and replaced the axel. I still don't have brakes and the lights are still on.
Friday, October 10th, 2008 AT 7:43 PM
LEGITIMATE007
  • 5,121 POSTS
If the pedal is hard, or even soft for that matter then your problem is gonna be with the pressure switch. Had the same problem with mine.
Sunday, October 12th, 2008 AT 9:51 PM
WILDFIRE2028
I have the same problem, ABS Light is on and BRAKE light is on and peddle is stiff. Where is the pressure switch located on a 91 Plymouth Grand Voyager 3.3L?
Thanks in advance
Sunday, March 22nd, 2009 AT 8:13 PM
LEGITIMATE007
  • 5,121 POSTS
It is located on the unit, and check to see if the tone rings have any chips on them first
Monday, March 23rd, 2009 AT 1:10 PM
