MY ABS LIGHT COMES ON AND MY GAUGES STOP WORKING THEN THE LIGHT WILL GO OFF AND THE GAUGES WORK AGAIN -WHAT WOULD CAUSE THIS?
Jun 16, 2009 at 9:53 AM
BILLYMAC
✓Experienced Mechanic
Hi kid is my fav i have everything he has ever done.
anyway this could be a cpl things. could be an abs prob but usually the plug in the back of the cluster is not makeing a good connection usually unplugging and reconnecting.. if not this it could be a bcm body control module. this would need diagnosed with a computor. hope this helps billymac..please feel free to write back with additional questions...billymac
Jun 16, 2009 at 11:48 AM
CARADIODOC
To add to the connector story, I've heard of quite a few problems caused by the connector pins on the instrument cluster. The pins become loose. The repair involves soldering them to the copper circuits.
caradiodoc
Jun 19, 2009 at 3:07 PM
