ABS light on, I do not have ABS
105,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
CHRISTIAN SKYE
My vehicle has had this issues since just before I had to have the clock-spring changed. The funny thing is that I do not have an ABS system at all. I have found places that say it may be the output speed sensor but nothing to actually confirm that and Dodge is no help unless I have $200.00 to $300.00 burning a whole in my pocket. Can anyone confirm this or offer any other ideas on what this might be. I also do not have wheel speed sensors at all. my hubs are flush.
Mar 13, 2017 at 11:47 AM
WRENCHTECH
  • 20,758 POSTS
I am afraid that you actually do have ABS in your vehicle. You need to have the ABS module scanned for stored codes.
Mar 13, 2017 at 12:20 PM
CHRISTIAN SKYE
I promise I do not have an ABS system on this. there is no controller installed and Dodge did tell me that my VIN number says it does not have one as well.
Mar 13, 2017 at 12:25 PM
WRENCHTECH
  • 20,758 POSTS
If you have an ABS light on, that means the truck is wired for ABS and the ABS module is the component that is turning it on. If it did not have ABS, it would not even have a bulb in that socket so maybe someone removed some of the components for the system.
I would follow the brake lines and see where they go.
The only other explanation for this is an incorrect dash cluster that is also defective.
Mar 13, 2017 at 12:32 PM
CHRISTIAN SKYE
I am very confused. I had this a year before this happened. tried to fix it myself, could not figure it out, so I took it to a mechanic to have it checked and he quoted me $4,000.00 to install all of the missing ABS components since that was all he could figure was wrong. There is not a single ABS sensor, no wiring on the master cylinder except the level sensor and no wires to the wheels and no ABS controller on the master cylinder or near the BCM. I could install the ABS system, but I would have to install everything, mounting holes too, there are none.
Mar 13, 2017 at 12:45 PM
WRENCHTECH
  • 20,758 POSTS
If someone removed the components, they would have to either leave the valve assembly in place or re-route all the brake lines to bypass it so you should be able to follow the brake lines from the master and see if they go to a controller or look like they are all man made, re-routed lines.
We cannot rule out that the issue is the dash cluster.
Mar 13, 2017 at 12:51 PM
CHRISTIAN SKYE
The cluster is a possibility. I can check if it is original or not fairly easily by QA date. I should have checked that when I did the light switch assembly. I will look into that on Wednesday and update then. I think they brake lines are original, all of the mountings match and they go straight to the brakes, no detour.
Mar 13, 2017 at 12:58 PM
