1998 Plymouth Voyager abs light on
1998 PLYMOUTH VOYAGER
163,500 MILES • 6 CYL • FWD • AUTOMATIC
TAMEKIA
My abs light came on then went off. I then had my speed ometer and everything go off on dash. Then both abs light and check engine light came on.
May 15, 2010 at 7:05 AM
BMRFIXIT
  • 19,053 POSTS
Check for codes as 1st step
check for engine codes and scan for ABS codes
if communication error suspect ,remove and check instrument panel plug pins to board Soldering
May 19, 2010 at 10:57 PM
