Not sure of engine litre size? My info shows the pump gets voltage from the asd relay. Three relays, driver side fender lining, the middle one shows to be the asd relay. Compare the wiring colors in the diagram to the middle one. Check for applicable trouble codes, the relay may not be the problem?
SPONSORED LINKS
Wednesday, June 23rd, 2010 AT 3:10 PM
